- Jan 18, 2008
I'm new here and I need some help. I have been reading the threads here and seems that a lot of people with the 4.0 are having similar problems as I am.
I have a 1993 Ranger 4.0 5 speed 4X4 and have been having symptoms of sluggishness, almost like running out of gas, (maybe restricted exhaust?). I have replaced the wires,plugs and coil. I also found a vacuum leak in the brake booster, which I have changed. I removed the MAF and cleaned it as instructed here on this site. I cleaned the IAC also. O2 sensors were put on by the former owner, I found them wired backwards, and put them the correct way, that straightened out the idle. I was pulling codes 172,173,176 and 177. Now after I cleaned the above mentioned items and replaced the booster, I get codes 173 and 176. Could the O2 have been correct the first time and I have them wrong? How do we know which side what plug goes to? The harness for the O2's is loose from where the former owner removed the tranny to replace the clutch.
How do I tell if the Cat converter is on its way out? I know the cab has been getting warm, someone told me that is one sign, and the rough ride,sluggish engine,spit and sputtering, etc.....
Vacuum test shows a steady needle at 17inhg, fuel pump test shows 30psi KO,30psi KOER,30psi drop to 29psi for 1-5sec then 30psi on steady high rev (2000rpm @ 20-30sec). Will do a compression test tomorrow, dark to do it now and I am to tired.
Any help will be much appreciated.
-=Reno=-
-=Reno=-
