I'm lost rear lift
VF Gunrunners
Oregon
I bought a stupid Rough country lift now I'm trying to put in the rear Blocks (Yes I know Blocks suck) just to get me by till I get explorer springs and shackles but any ways I'm lost do I have to cut the bolt out from the spring perch ? Their Instructions ****ing Blow and their customer service team is a bunch of morons I would never buy from them again FYI
You should not have to cut anything. When I took my 7.5 out it was parking cables, brake lines, drive shaft, U-bolts and BAM, it hit the floor.
I got it all a part but now I have a bolt hooked to the spring perch and have no where to put this lift block unless I cut it
that bolt through the spring pack is your spring pin, if the u bolts and spring plates are out of the way its probably just stuck. jack the truck up and smack the spring pack with a hammer and the axle should drop away from the spring pack
Kick it. That bolt is supposed to stay in the spring pack, not the axle.
^x2 ive had a couple rusted in place.
oh ok that makes a lot sense lol I swear im not retarded ok maybe a bit Thanks guys
no problem. I have thoughts that hurt sometimes too
