- Nov 18, 2013
- Automatic
I guess I have sort of hijacked my own thread. If I should repost the following in a new thread??
Checked both coolant and intake air temp sensor readings before starting this morning. Both read 35degF. Five mile trip home from work, and the intake air remained in the 33-35 deg range, so no heating of the incoming air. I could not find any sort of preheat to the air cleaner or duct. After stopping and restart after ten minutes, intake air showed 44deg and cooled back down as started moving. Coolant temp came up gradually into the 190deg range, so temp. sensors look about right. Home thermometer indicated 34degF.
MAF at warm idle shows .5lb/min or a tiny bit more. I goosed it a bit while rolling and it jumped up into the 10lb/min range. Converting those numbers to grams/sec which I am more familiar with is approx. 4 gm/sec idle, and 75 gr/sec for moderate acceleration. Those figures seem reasonable when compared to the Buick which I have tested for many years. The idle reading is just slightly lower than the Buick 5gm/sec and the moderate power reading converts to about 99 hp. Maximum readings for a stock '90ish 165hp Buick 3800 is around 130 gr/sec or about 17lb/min if my conversion is reasonable. If I knew the voltage or frequency range for the MAF readings I could give it a whirl on the flowbench. GM uses frequency and I "think" Ford uses voltage?
The lean code on both banks comes up more frequently but is listed as a pending code? In any case, fuel pressure is 39 psi key on and 30 psi engine running. The pressure rises about 4 psi on shutdown over approx. five minutes, which I have seen many times before (warm trapped fuel). Manifold vacuum @ idle is 21 in.Hg and rock steady. I need to see about a software upgrade on my scanner to be able to see what the O2 sensors are actually doing? Could both be bad? No codes for the O2's. Are the intake manifold gaskets a problem child on this engine? I cannot find any vacuum leaks or bad hoses at this point.
