ignition points in a 2.8
roughranger
is there a conversion for my 85 2.8 to points? I would also settle to HEI also! thanks rough
i want to get rid of all of the wiring! iam just gonna rewire everything that i HAVE to have, its a off road truck so i want it as simple as possible! thanks rough
I used a Pinto dist with a MSD 6al. works great
i have a 79 2.3 out of a pinto, that should have what i need then? i think its duraspark so can i just slide it in or what? thanks rough
You'll need the distributor out of a 2.8L Pinto. Aside from the distributor everything else should work.
Check out the Duraspark II articles in the Tech Library.
Duraspark will run noticeably better, and not need to have quality points purchased and installed twice a year to run well.
A duraspark setup will cost as much as a points dizzy and 5 sets of quality points. Do the math.
