I took out the ignition cylinder so that i could replace a broken shift tube. No problem getting it out. Now big problem. It won't go back in. Appears to line up correctly, but no go.
The cylinder goes in part way. It stops where the "paddle" on the end of the cylinder that turns the ignition switch won't slide into the slot in the switch.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
