i need to get more clearance
probably around 2-3" depending on if they are sagged or not, i would suggest coil spacers to go along with them and the body lift too, that would be great for your truck, also welcome to the site
okay thanks
they are not sagged at all
and ill probly look into the coil spacers and body lift eventually
but for now im thinkin just the leaf springs to get a little lift on it
how big of tires do you think i could run?
with the springs, 31s. might rub a bit in front, but my 89 bronco2 used to have 32's and only rubbed at full turn, if your truck isnt sagged at all, probably 32s
alright cool, i was goin for 32s anyways
and eventually ill lift it more
but for now and especially in the area i live in a 2-3 inch lift and 32 inch tires will get you anywhere!
thats cool, u should stick around the forum a bit and post up some pics of your truck
alright i will do that
i just got my license a month ago and once it gets a little more damp and muddy around here im going to start wheelin a bit
lucky, i wont have my lisence for another 2 years, being the youngest on the forum sucks cause everyone else can drive lol
cause of this site haha, but im currently doing a SAS myself, thats somethin im proud of and not every 14 yearold would try
3" body lift should get you 33"s with some rubbing. 31's won't rub
2" coils/coil spacers and explorer leafs or shackles will get you 31's
The two combined and you'll fit 33"s easy. However, 33"s and a 2.9 don't mix with stock gearing..
If it were me, I'd shoot for 31's.
okay so in order to fit 31s i only have to get the 2" coils and then shackles in the rear as well as explorer leaf springs? is that all i would i have to do?
or will i need to replace anything else such as shocks or anything?
sorry if these are stupid questions but this is all new to me
if you do explorer leaf spring and shackles you will probably need new shocks. but you wont need new shocks in the front with coil spacers. but i would run coil spacers and shackles and 31s and call it good
alright so i will be getting those coils now sometime in the future. but what do i do about tires? i am wanting to get a relatively cheap pair of 31s. what do you reccommend?
