I need some advice
there are a couple bolts that hold on the carrier bearing, just take the carrier bearing and drive shaft out as one piece, and separate from there
i got the drive shaft out and laying on the bench, i just cant figure out what to do next?? how does the bearing come off???
Beef
i got it figured out, i didnt take the u joint out so i didnt see the nut holding them together:buttkick:
So i got it apart now, but i gotta order one tommorrow.
Thanks for the help
Beef
well, i got the Carrier bearing in today, it didnt help. When i backed the truck out of the garage it popped out of gear(which it has NEVER done before) the clunking is still there and getting worse, it popped out of gear again when i drove it down the road to.
Any ideas??
Thanks
Beef
I just checked the rear end, it seemed good, no metal in the bottom and everything seemed tight. All U-joints are tight and not locked up. I replaced the carrier bearing.
Is there anyway to check the T-case and tranny to see if something maybe wrong???
The fluid is full on the tranny, but i think im gonna change it since the truck has almost 200,000 miles on it.
Beef
