- Sep 7, 2021
- 2.9 V6
- Manual
- Total Lift
- 3"
- Tire Size
- 31x10.50R15
86, 4WD. Previous owner installed 2" coil spacer in the front. I added Tuff Country beam drop brackets and now have my toe and camber spot on. Caster is .1" negative. Alignment tech said to fix the caster, I would need to drop the radius arm bracket the same that the beams dropped.
1) I have no idea how much the drop brackets dropped my bracket but it does not look like much
2) Can I lower the bracket by redrilling the side holes on the bracket and put a slight spacer between the bracket and the chassis?
I feel like I can lower the bracket a 1/2" or so, not comprimise it's strength and get the caster almost positive. No?
