I need an opinion on these compressions numbers...
Hoosierman
Forum Member
Indiana
Still trying to sort out a no start condition but I keep thinking back to the valve lash adjustment that I performed when I had everything off because of the leaking valve covers. So I did a dry compression test on all six cylinders and here is what I got:
1- 110psi
2- 140psi
3- 145psi
4- 150psi
5- 150psi
6- 140psi
I even retested #1 with an ounce of oil in the cylinder and it read 120psi thereafter. I know the 110psi is a significant drop (more than 15%) from 140. Significant enough to make a difference?
That shouldn't prevent a start.
Didn't think so.
About the low PSI number, should I look to adjust the valve lash anyway?
Didn't think so.
It certainly wouldn't hurt. Fingers crossed that's all it is for you 🤞🏻
If you’re looking for a no start problem… you didn’t find it there. I’d leave that alone until you find and fix the no start problem.
Fix one issue before you dig into it a create another.
My 2.8 had enough blowby it would push out the dipstick and spray the exhaust manifold with oil... and it still started great.
I agree, your problems are elsewhere.
you knocked something loose or maybe.....have slingblade check for gas.
Did it run before you fooled with it?
Spark... fuel... compression
Compression isn't it.
cap rotor fuel pump carb
I would think you're aware.... but many 2.8L people swap to Duraspark and replace the feedback carb.
There is a bunch of info in the Tech Library and 2.8L forum for how to get there.
I've been through all of the tech articles, I've searched this forum and others numerous times, scoured posts and written notes. I have an original 2150 non feedback carb already on it. Spark is blue and strong. Fuel is getting in, occasionally it backfires through the carb. I recently removed the carb to inspect everything (it was rebuilt before I got it, everything looks fine).
I just don't know. That's why I thought I would give compression a test, but it seems like other than cylinder 1, I am a-okay. As for timing, I have been through that rabbit hole more than a dozen times now. I finally found my timing light (lost in a move) and intend to check that next. I guess I'll double check the gaps on the spark plugs while they're out just to be sure, I mean this whole thing could be a result of stacking errors.
Should I try an HEI coil instead? I forget the numbers as I've got other things I've been doing, but I remember checking voltages and ohms and the canister coil's numbers seemed okay.
Thanks for checking my numbers everyone! At least there seems to be a consensus that the compression isn't the cause.
Backfiring through carb is usually timing.
Yeah but you'd think after setting it more than a dozen times, you'd get somewhere. So I paused on the timing and looked at the carb and compression just in case something else was amiss there. But I recently found the timing light so I think what I'll do is find the wire that is closest to TDC and set that as cylinder #1 and reorder the wires from there, just to get started.
You’ll get it. We’re all pulling for you. 🤞
