I beam travel specs
Socal
Hi, I have a 93-97 Ranger I am hoping to keep the stock height, stock tire size, but increase travel on it. I am willing to cut out fenders, redo the shock towers both ends, and do radius arms.
How much travel can I pull with stock beams and stock leafs? Any other tips.
stock tires .
you will want hydro bumps....or some sort of bumps. you need longer travel shocks and springs to work with longer radius arms.
to keep ride height this requires taller mounts/buckets
this feasible controllable travel limit is dictated by beam length.
steering from there is a trick.
there are lots of options.
As long as you are at it, you might want to do suspension upgrades all around: torsion bars, leaf spring clamps, traction bars, shocks.
