I am NEVER Wheeling AGAIN.......
I have one not sure if it helps you man from my lift install
PBR , any way you can get a pic of the beam where it goes into the bracket , i need a good pic along the length of the beam to see if it is straight or has a bend in it
I have a d28 beam i can get pics of for ya my buddy. if that counts.
shitty about the tree
i think that is the same setup , i dont think they changed brackets , thanks if you can get it for me
k ill get em tomorrow when i go over to the garage
I can try it's back under the truck though it doesn't look tweaked how does it compare to your passenger side? I will try to remember to snap a pic after work tomorrow
well i compared it to my neighbors 2WD explorer , that is the closes thing i have to compare to , the beam almost looks like it has to be straight , and the end is bent to like a 7 or 8 degree angle
I was bored so I snapped a couple for ya hows these any help?
well those give me something to compare the radius arm to , thanks man
the end of the beam looks bent to me
and also a good front bumper would have stopped most of that damage
Kinda hard to get a good pic in the dark lol let me no if you need others I can try and snap a few tomorrow
how did u get the drivers side axle out? i have to replace ball joints on my ranger. doe sit just pull out?
to get the axle shaft out you have to remove the spindle first ( NOTE: The Spindle and Knuckle are 2 separate things ) , to do that there are 5 nuts , then you have to pop the spindle out of the knuckle , the the axle shaft just slides out
