- Sep 14, 2007
- Age
- 44
- Virginia Beach
1998
- Automatic
Hi everyone,
Not too long ago I bought a house that needs a bunch of work. I'm pretty familiar with most things except HVAC. In 2011 the previous home owner had a new AC unit installed. It included the air handler/heat pump, which is located in the garage and the condensor unit outside. All the existing ductwork was left in place.
One night I was working on the house and heard the condensor fan outside cycle more than I expect. It wasn't abupt and didn't sound 'broken' or any noises out of the ordinary, just simply turned off and back on. So I monitored for a bit and I couldn't put an exact pattern on it. But the best way to descripe it is, the fan will turn on and run the heat pump for a while. Then the fan will turn off for anywhere from 30 seconds - 60 seconds. It will then turn on for about 2-5 minutes then turn off and the cycle repeats. It's not always like this, but something along these lines. I noticed more cycling when it is colder inside. For example, if the inside temperature is 60 and I set the thermostat to 68 it cycles more then if the inside temp was 66 and the thermostat is set to 68, in my experience so far. So I checked the filter (it's one of those cheap fiber ones), pretty much spotless. I then thought maybe the freon was low and causing it to cycle. Called an HVAC guy to come look at it. He said the freon levels were right on the money, so he looked around some more. He ended up calling his boss and they determined that there was not enough return air and it was choking the system out. The reason the condensor fan is shutting off is because it is going in to a 'protect mode' and it's not causing any damage. To be safe I haven't been running the unit. But I am wondering if this could be causing damage? I am somewhat sketical about his answers because he had consult someone else for almost everything. I think the job was a little over the technicials knowledge.
The unit is a Trane 3 ton electric heat pump with aux and the condensor is a Trane XR13. I don't have the exact model of the air handler on me but I can get it of need be. The house is two stories and is almost all rigid duct between the floors. There is are two returns as well. The return downstairs is a straight shot to the air handler plenum. This return is 12" diameter. The return upstairs starts out as 10" rigid duct in a hall, then goes in to the attic and makes a U turn down a wall between two closets. When the 10" duct meets the first floor it changes to 6x12 square rigid (I think because of the tight spaces with the supply duct. The 6x12 then enters the garage and connects to the air handler plenum. I've done my best to draw out the supply (red) and return (blue) and how the second floor return snakes through the house. I don't see any way to upgrade the second floor return because of closets and wall construction. Even if I could, it runs in to the 6x12 return and that would need to be upgraded too. I was thinking about upgrading the return downstairs from the 12" to 16".
A lot of things I read indicate I should 400 CFM per tonnage for return, therefore I would need 1200 CFM. Mathematically I should be seeing around 765 CFM, but realistically I think it is a tad lower because of all the bends on the second floor return. I get this arrive at this number because the 10" duct upstairs should flow at 240 CFM and the 12" duct downstairs should flow 525 CFM. My thought was to change over to 16" flexable duct (the air handler plenum and return plenum are not perpendicular or I would use regid) which flows 1000 cfm. Between the two returns I should have a little over the needed 1200 cfm return air.
My questions is, do you agree that the reason the condensor fan is shutting off is because the supply is too low? Do you also agree that this hasn't caused damage?
Next, do you think I am going about this the correct way or is there a better way to do this?
If anyone has anything to offer I would greatly appreciate it.
Steven
Steven
