huuuummmmm
Cutter26
I'm not sure if I have a bearing going or if it is something else. I hear a loud humming wich sounds like its coming from the passanger side front tire when I turn left. The sound is also there at highway speeds. Not to long ago I changed my u-joints and when I had the bearings out They looked good. I greased them up when I put the front back together. I'm thinking that I might have tightend the hub assembly nuts to tight. I didn't have the socket for it so I just used a screw driver and hammer to tighten down the nut.
Or the outer nut might not have been tight enough and backed off. Id deff check out those bearings asap.
