Hubs wont lock
C00T3R
I put in N then 4low then 2nd. And hubs wont lock and Ive tried everything I can think of putting it in P and then 1st or just leave it in D. Can someone help?
i take it they are auto hubs?
need more info to help.....
l8r, John
Yea, they are the auto ones
well, more than likely they are toast...especially if your wheel bearing have any play in them
if it were me, i would convert to manual hubs
l8r, John
Yea thats what im thinking about doing, how do I see if my wheel bearings have any play? I know, Im asking noob questions...
the wheel bearings will loosen up over time, and the way the factory auto hubs use the spindle nuts as part of the engagement of the hub, the play can "grind" the teeth off the hub...rendering it useless.
easiest way to find out is to jack one side up and grab the wheel and see if it moves up and down while a buddy makes sure that it isn't the ball joints movein'
there should be a small amount of "play" but not much......if there is, now would be a good time to get the manual hubs and conversion nuts and have the wheelbearings checked and repacked
l8r, John
Alright thanks, youve been alot of help
thanks, try to help when i can:icon_thumby:
l8r, john
Auto hubs only seem to work when brand new lol...just replace with some warn manual hubs or something similar and get the manual hub conversion kit which will include the locknuts and such...simple to swap out and way more reliable hope that helps.
