- Dec 31, 2017
- NJ
- 4.0 V6
- Manual
- Tire Size
- 245 75R16
I received a new clutch release bearing as part of a clutch kit.
I can't figure out how to slide the old release bearing off. It looks like the sleeve that it slides over has a clip that must be removed, but it doesn't look like it is removable.
Does anyone know how to remove the old bearing?
Thanks
Also. any suggestions for lube on the shaft? the kit came with clutch/brake lube. was wondering if that should go on the splines, and or the part that fits into the pilot bearing?? Where the release bearing contacts the clutch fingers?
Thanks
