how much lift can alignment eccentrics fix?
Ktmkris
10+ Year Member
I have a 1992 for ranger. It is a 2wd 2.3 5spd regular cab in calypso green. I put 10.5 inches of lift on it (going by the manufactures) in return the actual lift it recieved is 11.5 inches plus tires. This was built on a very low budget.
I installed a full pro compe 5.5 suspension lift (purchased brand new off craigslist for $300,
on top of that I added 2 inch daystar spacers(i purchased from oreilly auto parts on return for $6).
3 inch performance accessories body lift. ($100 off ebay)
35x10.50-15 super swamper boggers.
Truck has 5.13 gears and a detroit locker. Has absolutely no issues with taking off, will spin very easily, and can maintain 65 mph.
My issue is the 2 inch spacers have mad a positive camber issue.Being my lift plates were only made for 5.5 inches and they are now dealing with 7.5 inches of lift.
Can 4 degree eccentrics bring the camber from 2 inches in check?
yes and no.
need to know where it is at exactly and what current eccentrics are.
if there are current 0 deg or close for cam eccentrics, then the 2-3 in over lift of the brackets is correctable, easily so with 3 deg bushings.
what is not easily correctable is the steering at that height, and depending on tire size can be readily dangerous.
Not exactly sure what you are talking about the steering being dangerous. What is so dangerous about steering at that height?
I have replaced my pitman arm with a 8 inch lift skyjacker unit. So all of my steering joints are not stressed no more than any other lifted truck. As stated tires are 35 10.5 15 swamper boggers.
dangerous is a relative term in light of actual use, hp levels and tire size......but a true 8 in drop pitman arm, not sure where you got that, (even the fa600) is potentially dangerous as the stress levels it puts on the sector shaft is enormous.
i have broken 3 sector shafts in my regular rbv with oem and 4 in lift pitman arms, and ripped the box right off the frame on a few vehicles.
i never went wheeling without at least one set of steering linkages with me. But i always run a v8 that exceeds oem powerlevels, usually by double.
so if its a mall crawler and no hard 4x4 use the oem links at this height are quite acceptable for many depending on tire size, type and quality.
but ideally a k link should be the minimum for safety and reliable strength in handling.
based on personal experience, i would not use the oem links with a true 8 in bracket lift.
