How many run the Exploder 8.8 Disc?
BUMP....still need suggestions for pinion angles for 2" of lift. The tech section said 6 degrees but didnt say how much lift was necessary...I need to get the angle off the one in the truck now with the weight of the vehicle on it, correct?
That would be ideal IMO.
Lift kits should be set up to go with whatever the factory pinion angle was.
ive got an explorer axle in my 95 ive actually installed 3 of them. what i did aws i made some spring perches and welded them on top of the axle. i left the bottom ones . i measured on the back side and the front side evenly of the bottom pad to the top of the new pad this set my pad level with the bottom one and i havent had a problem yet. an i have 6 inches of lift.
Setting the pad level with the bottom one would make negative caster...Thanks, but i think i'll dial it in with a caster gauge. I appreciate the input though
