How do I trick the speed sensor
Pullman
ID - USA
Vehicle
Drive
1993 4.0 4x4 manual
The speed sensor wires got ripped out of my t-case how do I trick them into thinking im not moving? So i can use 4 low thanks!
Have you tried it with the wires just taped off and disconnected? That should give you a zero speed signal, unless the ECM recognizes that it doesn't work and locks it out with the software.
There is a red w/ white stripe wire going into your T-case module. If you cut it and ground the end going to the module, you will have shift on the fly low range. I highly recommend that you don’t do this. It could cause all sorts of damage if shifted at the wrong time.
Yeah, there is no way to trick the t-case, it doesn't need the speed sensor to know if you are moving or not in neutral.
