How do I ID the 5speed Trans in our6 88 4x4?
BillRod
Colorado Springs CO
Hi
We have an 88 Ranger 4x4 Extended cab with a 5speed stick.
It sounds a little whiney at times.
I wanted to change the fluid but the 88 uses either a mazda or mitsubishi.
One uses mercon and one uses regular gear oil but I'm not sure how to tell them apart.
I looked under the truck but I do not see any tags attached to the tranny.
Thanks in advance for any help on this.
Bill
I believe its the Mitsubishi.
I just checked another thread and a guy has an '88 4x4 w/ a 2.9L and the trans is a Mitsubishi FM146 5-speed.
Quick and easy way to tell:
If it's anything but a 2.9, it's a Mazda.
2.9:
If it has a removable bottom cover and removable bellhousing, it's a Mitsubishi FM146. If it's all one cast case, it's a Mazda.
Hi Guys
Thanks for the replies.
I guess I should have added that it is the 2.9 engine.
The tranny does have the flat steel pan on the bottom of it, with the I guess it is drain plug in the middle. So that would make it the Mitsubishi.
I want to change out the fluid because it sort of reminds me of my old 65 chevy pickup with the 3 speed and whines some when accelerating.
Thanks again for the help.
Bill
