Hi,
I am trying to get all the air out of the power steering system, since I just replaced the pump. I went through a quart of steering fluid and there is still air bubbles in the system. The pump makes a loud whine. I disconnected the return line and plugged the outlet on the reservoir, then cranked the engine after removing coil wire. Is there any better way to do it, or just keep putting fluid in and cranking. It seems like it should take less than a quart of fluid to bleed the system?!
Thanks for any advice!
Anthony
Anthony
