How can I keep my 2.9 cool?
jkufen
Charleston, SC
I tried to search through the forum for threads but really didnt find anything that answered my question. What can I do to try and cool down my 2.9? I never had an issue with the heat before but over the past few weeks it has been running hotter than usual. We all know that the 2.9 is notorious for running hot. I flushed my radiator and put new coolant in the radiator. Is there a different degree thermostat I can put in it? Would an electric fan be better? What are some of yalls tricks that yall used? I spend on average 2 days a week in the mud which usually involves me and the B2 at high rpms :badidea: so I really want to make sure that I can do what I can to help keep it cool as possible.
How do you know it's running hot? What temp is it running at? Is it staying around 210 F? Are you basing this on the factory gauge? Are you sure it still works properly?
One thing you can do is upgrade radiators. Spec out an HD radiator from a 90-92 4.0 Ranger or 91-94 Explorer (other models/years may work also, but I know those are a pretty straightforward swap, only the bottom mounting holes need to be modified slightly to work in your BII).
The electric fan probably isn't much of an upgrade for cooling capacity. Most aftermarket electric fans don't flow as much as a factory mechanical. Make sure the fan shroud is in place, if not that will make your cooling system less efficient since the air isn't being directed through the radiator as well.
If you want to run an electric fan, grab one from a Taurus, they move tons of air.
Sent from, wait how did this get here?
I am going by the factory gauge. I assume its working properly. It rises like it should but no im not certain that it is exact.
The factory temp gauge is an idiot light. It only knows cold, OK, and too hot. If it says C, it is cold. If it is between the lines, it is OK, if it says too hot, then you have a problem.
I also flushed the radiator on one I had, took it out flushed it seemd ok. got warm again, a guy from here told me to feel my radiator for cold spots, and sure enough , that was it. I bought a new radiator, hoses and transcooler, changed thermostat to the cooler one and never had another problem. The old one would work alright if I was on the hwy, at a regular speed, but slow down or stop and it started warming up. these motors will not take heat well, If you keep them cool they will run great.
What degree thermostat should I get? I havent changed the thermostat yet. I have seen the different degree thermostats but wasnt sure if higher the degree the cooler it would run or the hotter. My factory gauge stays in between the normal lines but it stays up at the 3/4 mark on the hot side.
NO, do not do this. The factory radiator on a 2.9 is PLENTY. A 4.0 radiator is not an upgrade, you are gaining a huge amount of coolant and a 2.9 won't keep it hot enough. The coolant temp sensor will read cold all the time and your gas mileage will go straight down the shitter.
Myself and others have done this and it turns a 25mpg engine into an 11mpg turd!
Factory spec 195* thermostat should be fine, if it's overheating with that, you have a problem elsewhere.
Eh, the Explorer radiator is working ok for me, the one I used was for an Explorer with a manual transmission and A/C, single core. It's aluminum/plastic tank and it was significantly less expensive than the copper/brass ones available. Engine heats up to normal operating temp (as indicated by my aftermarket temp gauge) and stays pretty close to normal.
I also don't daily drive this vehicle and I've never checked the fuel economy on it so I dont know what effect radiator would have on fuel economy.
It could be a few things, plugged radiator, thermostat, fan clutch or water pump impeller. Have you changed the radiator cap lately if the system goes into a high pressure where the overflow is not working correct that can also cause cooling issues. I would start with the cheap stuff first radiator cap. thermostat 195 deg and fan clutch. When your running high revs at slow speeds yes you need to increase air flow through the radiator to exchange the heat it produces. Also was there alot of rust in the radiator if so there is probably alot of rust in the block also. get a new water pump and blast the block out good with high pressure water before you put the new pump on. If stock its a 27 year old motor do you know how old the water pump is?
No not real sure how old the water pumps or thermostat is. Today it ran nice and cool right in the middle of the gauge. I am wanting to replace the thermostat and water pump but since it does keep me ok most the time I have bigger fish to fry unfortunately. I have heard the horror stories with high heat and the 2.9s so I am cautious
The 2.9 is not "Famous for running hot" it is however famous for cracking if it is run hot.
What it is less than famous for is instrument issues.
THE wire to check is the ground between the back side of the driver's side
cylinder head and the retaining stud on the wiper motor
This ground is often the culprit.
But remove, wire-brush then reinstall the sender unit
DO NOT use "Teflon tape" on the sender unit, it MUST make good
electrical contact.
First I've heard of this....
I put a 180* T-stat in my choptop and a radiator out of an Explorer (no modifications required other than I had to change my lower rad hose). I've been running an aftermarket temp gauge and gets up to 180* and stays there no problem. I also put a new water pump on it a couple years ago. I was getting 18 mpg with it around town with the old bias ply 33's and all. And yes, I did correct for tire size and gear ratio.
Yep, that's blasphemy.
I have the two-core Explorer radiator ('94 w/auto & AC) and a 195° thermostat for my BII's 2.9L. I get low-20s MPG easy on the freeway even with my big 35" MT/Rs.
An engine not reaching it's proper operating temperature means there's an obvious thermostat problem (that or it's like -55° out). The thermostat is supposed to allow only a certain amount of coolant through the engine for it to remain at the thermostat-set temp (the amount of coolant within the radiator itself is irrelevant).
To the OP,
The Explorer radiator swap is all bolt-in IIRC other than you have to swap the lower radiator hose for it to mate up with the Ex radiator's angled lower port. Also, I've heard some say their upper hose gets pretty close to the alternator after the swap, however mine seems to have plenty of clearance (my BII had the swap already done when I got it).
I love the Explorer 4.0 radiator and I'm running an electric Volvo fan. The only issue that bugs me is cruising at around 70, the temp may climb up to the "o" in Norm on the guage--not all the time and not because of outside temp. I think the water pump starts to cavitate sometimes and can't flow water as it should. At low speeds the electric fan does a great job of keeping the temp on the "R" or below it in the Norm range.
