Honk Honk!!
mbub16
St. Louis
Can anyone help me through troubleshooting my car horn on my 97. I went out but it would work every now and then and now its completely out. Any help would be much appreciated.
Horn grounds by mounting to the body. Check to see that the mounting bolt is not loose
Also, hook up a multi meter to the leads and hit the horn. If you get constant voltage the issue is not the switch. Doesn't help you figure out what is is but will help you find out what it isn't. Process of elimination.
