home built lift
this truck sees some asphault but just as much dirt and its got cheap tires on it. how far would the camber be off if i used the 2 degree correcting camber bushings
get the adjustable 3.25/3.5 units and run the longer arms with the bracket moved back.
should allow 3.5 over stock. you may have to trim the 150 coils to bring the lift down or shim em to go up...hard to say, depends on how beat used coils are or what coils you buy
