It gives up nothing on bottom. Mine pulled from idle to 6000 rpms, used with a set of 1.7 Cobra rockers. Here was my combo: Explorer short block and cam, ported E7TE heads (done by me), basically the only thing I did was open up the exhaust sides of the heads and bowl blend the area under the valves on all. Intake was a Ford A321 (same as the old 60's Cobra high rise dual plane) Holley 570 Street Avenger, points distributor with a Pertronix II, fired by a Mallory Promaster coil, timing set at around 14-16* BTC. I ran this with a Toploader 4 speed for years, then swapped in a C-4 with a TCI street fighter converter. Rear was an 8.8, 3.73 tracloc with 275/60/15 Cooper Cobra's. Oh, and tri-y headers and full duals with a 4' x 12" equalizer chamber forward of the turbo mufflers
