Hissing sound from brakes
Dragstart
Forum Member
New Smyrna Beach
FL - USA
Vehicle
Drive
2WD
3.0 V6
I first noticed a hissing sound when I would have brake pedal depressed at stop light/sign. It has now progressed to being able to hear it without pedal depressed. But, if I depress pedal all the way down, hissing stops.
Of course, it's engine vacuum, but my question is what to suspect? Is it the check valve, (which seems to be OK, removing it and pulling and pushing air through it.), or is it a hole or tear in the booster diaphragm?
Brake function is normal, but can/will the booster finally completely fail?
Or is there a seal around the brake pedal rod where it goes into the booster that is failing?
Thanks!
It's most likely a bad booster diaphragm.
Which means you need a new booster.
Not long ago I had to put a booster in our Edge... same symptoms.
Hmm. I guess every truck I've ever driven has had a bad one then. Never been in one that didn't have the whoosh when the pedal is pressed. Brakes always seemed fine to me.
There is a difference between the whoosh sound as the pedal travels and the hiss once brakes are applied
Yep. There's a difference. Thanks for the replies. Already been shopping for a new booster, sorta figured that's what it was, just wanted opinions from you all that have 'been there'.
Just changed my booster out $105 at Advance. Seems like I have non-linear braking now. Didn't have that with the old one which was hissing.
