Hilift jack to slider adapter.
RockRanger
20+ Year Member
Fresno CA
One thing most wheelers carry is a hilift jack. It seems like every time it is used the jack has a tendency to slide on the sliders and seems very unstable. I built the bracket below to help grab onto my sliders and hopefully make it more stable.
Here is the bracket.
20150901_134556 by Matthew Dresselhaus, on Flickr
It mounts onto the jack with a 1/2" bolt holding it to the jack.
20150901_134829 by Matthew Dresselhaus, on Flickr
Here is how it latches onto the sliders. Mine are 1.5" tube. I forgot to account for the weld on the back side so version two will be changed there.
20150901_135037 by Matthew Dresselhaus, on Flickr
Here it is lifting the truck. For the front I carry a chain to limit wheel travel so I don't have to jack so high.
20150901_135246 by Matthew Dresselhaus, on Flickr
20150901_135302 by Matthew Dresselhaus, on Flickr
Toss it in the toolbox and hopefully I will never have to test it for changing a tire.
Made a few modifications to this to make it more useful.
20151002_123825 by Matthew Dresselhaus, on Flickr
First I went to a "V" shape so it would fit different size tubes. I also added a second hole and made it reversible. There are 4 ways this can be used now.
First is on the slider tube and the spacer tube. It can be mounted on the fist or second hole depending on if you need clearance to clear the body.
20151002_124622 by Matthew Dresselhaus, on Flickr
20151002_124055 by Matthew Dresselhaus, on Flickr
The third and fourth is flipped around just on the slider tube. This allows for more clearance between the jack and body.
20151002_124447 by Matthew Dresselhaus, on Flickr
20151002_124308 by Matthew Dresselhaus, on Flickr
Here it is shown on 1.75" tube joint.
20151002_125348 by Matthew Dresselhaus, on Flickr
Here it is on my Wife's cj7 jeep sliders. They are much larger in diameter then designed but I think it is better then without.
20151002_125003 by Matthew Dresselhaus, on Flickr
I think it turned out really great, Bro!!! It looks real sturdy and should hold up really well after a lot of use. Test it out a bunch and see how it holds up. I would Powder Coat it and make many more and put them up on Ebay and a few Offroad web sites if I were you. I just gave my Hi-Lift to a buddy who could not a afford one. He and his wife just had a kid two months ago. I hope I never need one now that I gave it away....lol.
I like it. I'll be copying that idea.
Frankly I like the idea, but I disagree that powder-coating would be an improvement.
I'd rather see it plated.
Or galvanized...
The idea of powder-coating is a novel one in industry but the end result in everything turning into crumbly rust...
AD
