- Jul 15, 2009
- Butler, PA
- 4.0L
- Automatic
- Tire Size
- 31”
Change the oil every 5000 miles and not 10,000 like the manual says. Replace the oil lines to the turbo at 100,000 miles. They have thimble-sized filter screens on them which will clog over time, especially if you go to the max mileage on every oil change. See FordTechMakaluoco or whatever his name is on YouTube.First one that I’ve seen over 200k. I have a 2024 on order with the 2.3 and wondering if I should wait on the 2.7. I think the 2.3 will be fine after seeing this one.
We've had great success with the 2.3L They are tried and true. Great little powerhouse. We change oil & filter every 5,000 miles...religiously.
As I live in Phoenix, my next point will likely garner me some feedback, but, I stand by it for MY environment and driving style. We changed our transmission fluid at 25,000. New filter and deeper metal transmission pan versus the original plastic pan. Enjoy!
Can you post a link to that aftermarket tranny pan? Does it have a drain?
CMOS
There's at least two options... one made by PPE and one made by Mishimoto. Both have drains.. around 300$.
Does the 10-speed tranny have a dipstick? If not, how do you know how much fluid to put in after installing the new pan?
CMOS
CMOS
2017-2023 FORD w/ 10R80 Transmission Heavy-Duty Cast Aluminum Transmission Pan
Heavy-Duty Cast Aluminum Transmission Pan - Ford 10R80 Transmission The 10R80 transmission from Ford is revolutionary. This 10-speed power manager can go from street to strip with a flick of a button on some vehicle applications. All this available Broncoppepower.com
When you replaced the Pan, did you reuse the gasket, or replace?
CMOS
I chose to replace with a new Ford gasket and Fresh Ford fluid
