- Aug 7, 2007
- Manual
Dude, you seem determined to spend money. Your cat MIGHT be ruined, but you have no reason to suspect it actually is. It's doubtful. You can test for it easily with a vacuum gauge.
The $200 you would spend on the cats would be better spent on professional diagnosis.
Odds are, this has nothing to do with fuel pressure, but instead is an electrical problem in the emissions system (e.g., broken ground wires). Basic diagnosis STARTS with the spark plugs and self-tests.
Does your check engine light work? It should be lit with the key on, engine off.
