bronco 2 bud 10+ Year Member Joined Mar 13, 2010 Messages 2 Points 3,001 Vehicle Year 1990 Transmission Manual Mar 13, 2010 #1 can anyone tell me why gas would be in my break booster? it went bad, itook it off, and there was fluid that smelled likegas in it.
kimcrwbr1 15+ Year Member Joined Dec 6, 2009 Messages 6,044 Points 3,101 City maplevalley WA Vehicle Year 1983 Transmission Automatic Mar 13, 2010 #2 I believe that would be the fuel pressure regulator pull the vacuum off it and see if it smells like fuel also
adsm08 Senior Master Grease Monkey ⭐Supporting Member Article Contributor Ford Technician TRS 20th Anniversary Joined Sep 20, 2009 Messages 34,617 Points 3,101 City Dillsburg PA Vehicle Year 1987 Engine 4.0 V6 Transmission Manual Tire Size 31X10.50X15 Mar 13, 2010 #3 yeah, FPR diaphragm failure is about the only way that can happen.
lil_Blue_Ford Cut & Weld TRS Forum Moderator ⭐Supporting Member 💻 TRS Socials TRS Event Participant TRS 20th Anniversary TRS 25th Anniversary V8 Engine Swap Joined Aug 6, 2007 Messages 13,046 Points 3,101 City Butler State - Country PA - USA Vehicle Year 2000 Vehicle Ford Ranger Engine 5.0 Transmission Automatic Total Drop 4” Mar 13, 2010 #4 Well, it's the most likely culprit anyway.
adsm08 Senior Master Grease Monkey ⭐Supporting Member Article Contributor Ford Technician TRS 20th Anniversary Joined Sep 20, 2009 Messages 34,617 Points 3,101 City Dillsburg PA Vehicle Year 1987 Engine 4.0 V6 Transmission Manual Tire Size 31X10.50X15 Mar 13, 2010 #5 yeah, someone could have dumped fuel into your booster.
