- Sep 30, 2007
- Age
- 44
- Lindsay Ontario
- Automatic
Ok, so, hears the low down. My truck wont start:
There is Spark at the plugs.
There IS fuel in the fuel rails, but i dont know if the injectors are firing.
Engine roll's over without problems, but shows no life. When cranking for a considerable amount of time, it will fire one then die. I have checked the coil, its ok. TFI modual is ok, im asuming, because im getting spark. The only codes are for the intake air temp, and ECT being out of range, which isnt a surprise, its -18c out. I will be getting a Fuel pressure tester tomorow, so i can test pressure. Also, there is 1/4 tank of fuel. i have dumped in some fuel line antifreeze. but still no change. Im looking for some ideas about what i can check next befor putting it on a hook and sending it out. Im going into exams this week and dont have time to eff around with it.
