help wont start major proplems
kkeggers
i got an 02 ford ranger 3.0 the water pump went out and it over heated bad i changed the water pump and it wouldn't start so i changed the spark plug wires and plugs then i checked compression it was bad so i changed the all the gaskets from the block up and new battery it has spark, fuel and turns over any ideas any would be nice i cant think of any reason why it wont start plus the cpu for the truck hasn't any codes stored so my scanner is worthless help
Do the injectors pulse and the plugs fire?
yes i have 120 in all clinyders and all plugs have spark
Punctuation.
Get a scan tool that can monitor engine parameters and see if the engine is seeing engine RPM correctly.
How is your fuel pressure?
checked injectors they are fine
have u checked the block for any cracks. when cast iron blocks over heat they crack.
ya the blocks fine no warp and no cracks
