help wiring turn signals, on off on switch
spdcrazy
15+ Year Member
Homer, alaska
mostly 86
I'm wiring all new turn signals. Pics to come. But what I'm not sure about is my wiring. Using a three terminal on off on switch.
The middle terminal is 12+ ya?
With a flasher in the middle.
Then one side gets split to each turn signal for that side.
And each turn signal grounded at the signal?
after some playing around i was correct, HOWEVER, if you want to run LED's you must have the appropriate resistors or they won't flash, or even turn on.
the resistors have two wires on them, use it to jump from one wire to the other coming off the turn signal.
works like a charm. hopefully other ppl can find this in search now
