- Jul 7, 2009
- Manual
Recently I've had a curious problem with my '97 Ranger: if I start the truck after it's been sitting for a while (> 30 min) it will start like a champ, but if I try and start it after having driven for a while, it takes like 4-5 tries for the engine to turn over. The solenoid clicks and the starter motor sounds just fine (no grinding or bad smells or anything).
I've also noticed that at low RPM's (~1500), the voltage needle will wobble noticeably, which I have never seen before. However, I tested the battery and it is rock solid. Is this a starter issue, an alternator issue? Advice appreciated.
Thanks,
Aaron
Thanks,
Aaron
