- Oct 23, 2007
- Age
- 52
- Manual
Ok, looking for some help... 95 2.3 XLT 5spd.
I already tried the blenddoorfix.netfirms.com/ instructions. My actuator works properly. I also checked the top of the blend door (female end) and it moves when the heat control is moved from heat to cold and then back.
Other things... A/C blows cold. Blower motor works on all settings. The coolant hose (closest to the driver's saide) gets hot after the truck reaches temp. The other hose (passenger side) seems to be warm. The radiator is full (opened th cap a tiny bit and coolant came out).
What do you thing my next steps are? (I am not a mechanic but can fix most things given good ditection and maybe some pictures.) Wish I had more to offer these forums, but I can help with plenty of things on VW Vanagons
Thanks again!
