help the explorer wont start no fuel
dangerrangerstx
hey yall i did half of the work ichecked to make shure its fuel realatied because it starts on either:sad:. i checked the fuel pump mega fuse checked if the fuel shut off buton wasnt on. btw how can i get rid of that button.it started one minute and then the next it didnt any help would be apreciated
92 ford explorer
You need to establish whether the fuel is running or not first.
Got fuel in the tank?
Take a pressure test on the fuel rail, find the Schrader Valve, (it looks like a valve stem for a tire with a cap on it). Check all your fuses again. Reset the the inertia switch, try to start.
If you don't have 35-40 pounds of pressure at the fuel rail, it wont run, change the fuel filter, if it still doesn't run, drop the tank and replace the fuel pump.
Don't disable the inertia switch! If you roll your rig and the fuel pump keeps pumping fuel you could possibly burn up before you get out of the truck.
Ray
well the pump wont kick on no fuel comeing out of the shrader valve coul my pump just die like that?
Yes, but see if you are getting voltage at the inertia switch. If so, likely a bad FP.
If no power at inertia switch, try a new FP relay if CEL comes on when key is at Run. If no CEL, check PCM relay and fuse, also possibly PCM power diode; they all contribute to apply power to FP relay.
got it fixed no some other problems but i got pics
