- Oct 18, 2008
- Manual
Hey everyone. I am new to Rangers and am learning as I go. I found a 01 Edge 4x4 MT that was sitting for about a year. I fired it up, ran great, and stopped at the gas station to put a couple of gallons to make it the rest of the way home. I make it about three miles and then I start getting a horrible stutter (almost sounds like a mechanical knocking) when I am shifting from 3, 4, to OD. During the time of this stutter I am loosing a lot of power until the point that I am having to staying in 4th or 3rd to keep moving and then the engine finally dies. The temp and oil are where they should be the whole time. About a hour of tinkering with the battery, a friend keeps turning it over for about 10-15 seconds and it starts running. I drive for maybe a mile and it does the same horrible chatter and dies again. Before it died, I put it in neutral and reved the motor and there was no knocking coming. This chatter sounded so much like an engine knock or maybe some severe fuel starvation? I was lucky enough to be close enough to coast to my house. Now all it will do it just turn over and over and over and No Fire. I have been doing a lot of research and think it may be a few different things, but I am so sure this such a simple problem that someone might know right off hand. No CELs.
1)Fuel problem? Clogged Filter or Bad Pump or Inertia Switch?
2)Ignition? bad coil, faulty plugs/wires?
3) Intake? MAF Sensor faulty?
