- Nov 6, 2008
- Automatic
I have had a somewhat ongoing problem with my front brakes on my 2001 4X4 Ranger Edge. The brakes pull badly to the left especially when applied quickly. I almost had a head on with another car when a large doe ran in front of me when I was going 60. I hit the brakes and was pulled into the opposite lane. The pads are new and were replaced hoping that would fix the problem with it appear it hasn't. I believe it is the rotor on the left side as my aluminum wheel is always black with what I believe to be brake pad. Sound correct? and if so, should I replace just the left side or both? thanks~
Chances are your front passenger caliper is seized, and the front braking is all going to the left side ( most likely why its pulling to the left). With that said, 85+% of your braking is done in the front, where the weight is, so id get it fixed, because theres a good chance you have compromised brakes.
