Help Quick!!!!!!!!!!!!!!!!!!!!!!!
ok, got it,.. back to the truck to check it out againnnn. (yea im jus goin back and forth to my truck to the laptop)
If you have springs on the front suspension, you do not have torsion bars.
That being said, you crank on a bolt inside the mounting (third pic shows the mounting best) at the rear of the bar. The bolt is offset from the centerline of the bar (to the outside, I think), and the bolt changes the position of a key attached to the bar. Some key bolts have a lock nut on them. You have to look into one of the holes in the mounting. Use lots of lube, and make sure the tires are off the ground when you crank.
Cranking them will cause toe out, and camber change. You will need an alignment after you crank them.
k thanks, damn those bolts are tight
yes them bolts just remeber to count the turns and do the same amount on both sides
post pics when you get done.i want to see the lift,and a picture from the front so we can see the camber.
man, the impact gun cant even tighten them bolts
but i jus realized, if i use a impact gun i wont know how ,many turns it make?
o well, try the ratchet again
u might have to heat them to get them lose but i would use that as a last resort try penatraiting oil first and as long as ur within a 1/4 of a turn u will be all set also sometimes u can also use a big clamp and take some pressure off the bars it helps a bit sometimes
k, thanks, and ive already heated it a bit with the torch, but wat are you talking about with the clamps?
ok, just put 4 different oils and the torch on it, still cant budge it, i think its rusted on there pretty good
ok now would be a good time for some handy adviceeeee,
k guys seriously. i want to get this done by dark, and the sun is setting, i need this done quick, and i got school tomorrow
Please Helppppp!!!!!!!
nvm about the clamp it only works on GM trucks sorry just rememberd that sorry again the only thing u can do is heat it till it's glowing and try that or soak it with pen oil and let it sit over night if u break the bolt or strip the thingy the bolt screws into most of the time the dealer has them on the shelf and the're pretty cheap
alrite thats pissin me off im heatin up the bolt like a b!+ch and its not attempting to glow, sparks and shit but no glow, its only about -10 degrees here , i dont think thats too too cold
:annoyed:
wish i had school tomorrow.i have to clean tubes on 40 ton self contained water cooled air conditioners,5 total.
