- Apr 19, 2009
- kentucky
- Automatic
302 in a 85 ranger , all stock except for new duel plain alum intake..new 1406 edelbrock carb... new hedman hedders.. engine run great before i changed from a 2bbl to the 4bbl intake carb setup..now its only running on 4cyl.) now seems to be running on #5-8-2-3 cyl. when i can get it to run.. not running on #1-4-6-7 cyl. checked firing order and that is good..checked dizzy with #1 piston up on compression. and rotor pointing at #1 on cap.. shows 0 on damper (TDC) ..i did pull all 8 plugs and all were wet with gas so i put new ones back in..why is the engine only running a 4cyl.. im dead in the water till i figure this one out..i mean all i did was pull the old cast iron intake and 2bbl carb off and put new 4bbl intake and new 4bbl carb on...lol...seems simple enough.. i checked and all plugs are firing
