- Jul 5, 2008
- Manual
Hi
I need some advice from you guys on what I should do with my ranger. I just dont know what the best option is. I have a 1989 Ranger STX 4x4 supercab with all the options ford offered in that year including the high rider suspension. I've own the truck about 10 years now and would like to own it another 10 years but i got a problem I dont really know what to do about.
You see about 2 years ago the top of the roof started to rust because the clear coat and paint had faded all way and I didnt get to it in time to save it. I'm STILL kicking myself in the ass over that one.
Anyway, I sandblasted the top of the roof as good as I could get it, Covered it in about 3 heavy coats of Extend rust proofing / rust fighting product and then painted it with about 3 coats of primer and about 3 coats of clearcoat to protect it. It didnt help much, a couple of months later I noticed the paint was starting to bubble again.
At this time I bought a pop-up sun roof for it because I got a great deal on it and because the worst of the rust would be right where the sunroof goes so I figured once that was cut out and replaced with a sunroof that would be good enough to save the roof. Nope....
Even though I took it to a " Professional " upholestry shop to have the sunroof put in and the headliner redone The Chitheads must have not done ANY metal prep on the sunroof hole once they cut it. They just thru the sunroof in.
Now the roof is rusting even worse then before I put in the sunroof and I just dont know what to do about it. At this point I feel like no matter how many times I sand down the rusty areas, cover them with a rust fighter and repaint them it will be just a mateer of time untill it comes back and destroys the roof of the truck.
Since it's the roof of the cab and not something simple like replacing a door or fender I'm not sure of what to do. I Love my truck and would like to put some money in it and semi-restore it and drive it another 10 years But not with the roof the way it is. it will rust away long before that.
I see my options as follows but dont know if some of these can even be done nor how expensive they would be and wanted to get feedback on it.
1 - I continue to grind, sand, treat, and paint the roof untill the rust finally overwelms the roof, it starts leaking on me and I have to buy another truck
2 - Purchase another 89 ranger SC with a Good cab/roof and cut the very top of it off and weld it in place of my original
3 - Purchase another 89 ranger SC with a good cab/roof and cut the whole roof assembly off and weld in on to my original cab
4 - Purchase another 89 ranger SC with a good cab and just replace the whole freaking cab
I dont know IF 2 and 3 could even be done, how much it would cost to do and how to find someone good enough with welding / bodywork that they could actually pull off a job like this and get it RIGHT.
Replacing the whole stinking cab just sounds like more work then I want to do. God what a job that would be.
Anyway thats my issue in a nut shell, I love my truck, I want to save it, But I need a little help and advice. Help me save my truck. What would you do if it was your truck. Thanks......
LV
LV
