Help make it start...
NakedDucks
Neighborhood Blight!
B’ham
AL - USA
Other
Lisa. 2020 White Honda Odyssey.
Vehicle
Drive
God’s plan, not mine.
Bought a B2 that had a busted transmission shaft that I had never heard run. Trans was already removed..... figured it was running when the trans blew soo...
Was the FM146, so I removed the bellhousing, and just bolted it back onto the 2.9. Installed the starter as well, and the 3/8 bolt for the wire...
No start with key
Moved the clutch switch on the pedal.... no start with key
Jumped the solenoid....no start... no turn over
Hooked jumper cables to ground and start wire for starter... no turn over...no start.
Tapped starter with hammer.... same results.
Any ideas?
Only idea I can think of is to pull the starter back out and see if it's any good when hooked directly to jumper cables.
FWIW, I only want to start it to see if it will.... I plan to swap a complete underhood from a 94 Ranger 4.0 in anyway.
I'm sure you have, but I didn't see it mentioned soo... Is the battery hot and good terminal connections?
Since you jumped the started relay and it didn't do anything, It definitely sounds like a dead starter or bad wire.
I would take a socket and ratchet to the crankshaft and see if the motor is free and not locked up. Tapping the starter doesn't always fix a starter. Take the starter to your local part store and they can test to see if the starter is working or needs replaced.
When was the last time this truck ran? I personally don't want to crank a motor over if has been sitting for a long time. The rings can rust to the cylinder walls, and a starter is strong enough to break the rings from the cylinder wall and that can break a ring, eventually causing motor wall damage.
It had been sitting for only about a month since it last ran. I'm going to take the starter off and have it tested. I have a good feeling that's the most likely cause.
Starter bendix isn’t kicking out.
Don’t want to buy a new starter for a motor I don’t intend to keep….
Anyone got one I can borrow just to make sure this engine runs good? 🤣
Yes...
Come pick it up in Chicago.
Might want to wait til the National Guard shows up tho...
I’m lost….
What you mean by that?
The current administration is promising a ‘war on crime’ in Chicago soon.
Been talk of sending the National Guard to Chicago to help fight the crime epidemic. The place would be much safer
Well, ship it to me, and I’ll ship it back with payment for shipping both ways.
Think I’ll stay safe down here.
UPDATE:
Sold the Bronco II to a friend who wants to keep it a 2.9.
Bought a Bronco II with PERFECT body and red interior. Was an auto, electric t-case.... but a previous owner spray painted it a nude-yellow-tan(ish) color that I will need to sand off.
Plan to paint it grey with red accents, 4.0 swap it, M5OD swap it, chop the top, remove the doors, and weld on the ends of a ranger bed so i can have a tailgate. Gonna incorporate a B2 tire carrier.
What you guys think?
Do a real tire carrier if you plan on bigger tires. I was looking for a factory tire carrier for my Bronco II... was talked out of it for 33's.
Lose the liftgate... Do the tailgate... pop out the windows... spare the roof.
Why do you say spare the roof?
