Help identify rear axle.
rowdy_g
U.S. Military - Active
Colorado
1993 4.0l v6 XLT
Tag says 7.5 but looks like an 8.8. Axle tag is too far gone to read. I'm assuming the white paint marker is indicating it is a 5.13 axle ratio.
75327
75328
The truck came with the 7.5" open with 3.73 gears https://www.therangerstation.com/tech/ford-ranger-rear-axles/
The best way to know the gear ratio in your case is to pull the diff cover and look at the stamp on the ring gear to know.
To get a 5.13 ratio set of gears it needs to be a 8.8" as they wont fit in a 7.5". The 5-13 could also be the month and year the diff fluid was done also.
Thanks for the reply! I didn't think of that being the date, but it probably is. Needs a new gasket so I'll check the ring gear. It has a lift and big tires. Thank you.
  • Help identify rear axle.
It looks like an 8.8 because it is one. A 7.5 rear cover is flat top and bottom with sides that look like parentheses (__), an 8.8 looks like a square with the corners rounded off, as in your picture.
