Heat under the seat!
falcon57
Hey you console fans.. Have any of you seen the option on exploders that provide heat via duct towards the back of the cab? Has any-body tried this conversion; as far. I don't see a problem looks possible!
You will have to grab the air ducting from behind the Explorer dash and swap it in as well.
swapping ductwork
I wonder does exploder have a varient in plenum control accesable by driver?
can you say that in normal terms?
are/is the heater controls the same. cable throws/slide assembly. Come to think of it is the blower the same? I'm guessing their pretty much the same.
They are all the same unless you get an Explorer with the EATC in it. If it has the EATC in it, some wiring is different and the blower motor resistor is different.
Great! Thanks-for the info.
do a detailed thread on it, jim could ad it to the tech section
