Hazard flashers not working
3.0ranger1227
What would cause my hazard flashers to stop working? when I hit the button, the blinkers stop working but nothing flashes - no indicator light in the truck flashing, no flashers outside the truck. Anyone else had this problem?
All the fuses are good, Have switched the flasher relay. Will try it again. Thanks
Any other ideas?
Its possible. I'm about to go run through all the fuses and relays. hopefully its not a bad ground - don't really want to chase that down in the 100 deg houston heat.
Had same problem. Turned out to be the hazard button was sticking or was gummed up with something. Kept messing with the button and she began working, again.
Bulbs work... All my lights work. I'll try just messing with the switch
