Having some trouble with the tech library tire charts.
koda6966
The green part of NY.
They won't show up for me. :dunno:
Anybody know what size tires I'll be able to fit with a 5" rear, 4" front suspension lift and 3" bulge fiberglass fenders? This is on a gen III ranger, 2WD. If the 4" in the front is a problem I'll just throw some washers in there and get 5".
I mocked the truck up with all my stuff, and it comes out looking pretty silly with the 215/60R15 tires I have on it for rollers.
The tire fitment chart says 33s. I think a lot of guys running 4" inch can clear 33s pretty good with the fender flares.
i'm thinking more like 35's atleast... 33's w/ all that is a little crazy.
i know you're just saying what the chart says. i say get the suspension done, then do some measuring from the center hub out and see what kind of numbers you come up with.
You'll clear 35's, the fenders help a LOT.
Cool. I wanted to be able to stuff 35's but the most I'd run is a 33" tire. Will I need to cut fenders in the rear for that or should I be fine? I'll definitely test the flex out after I mount tires, but I'd like to know because if I need to cut fenders I wont bother with buying an 01+ bed I'll just use my 93. I've got half the pieces to an 01 front end conversion and I want the rear to match.
The 35's will stuff out back, the wheel openings are 'just' big enough...
Cool. I should be all good then.
I wont be able to afford tires until next year, I just wanted to get it all figured out before so I don't have to tear my suspension back out and modify everything.
Thanks guys!
