- Feb 2, 2009
- Age
- 37
- Bemidji, MN
- Automatic
yeah im glad that its not tripping any more.Winter sux.
GFCI's might be great in a perfect world, but as people have said, they can trip when there is nothing wrong. Very sensitive and it's the times that you really need power that sensitive things aren't necessarily helpful.
Doesn't get that cold here but I've had to dig up the camp stove and push it under the oil pan to thin the straight-30 enough to turn the engine over. Trickle charger won't keep a pair of 1,000CCA batteries up either--I run the 10amp charger on them all night when it's going to be cold.
My new house has a 3-car garage so I was hoping I could keep the truck inside at night now. But it's too long to fit inside the garage. And there is no outlet next to the garage either so I'm a step behind you already.
im going to be getting my own charger when funds allow and this spring or summer a block heaters going in. im almost thinking of hitting the gas station up for a bag of BBQ Briquets to put under the engine. right now im running a i hope still good 850CCA Battery.
time to break out a non GFI plug and set it up just for your truck
