TimV
When the alternator was changed, did you have to reuse the voltage regulator from the old one? Its the small box attached to the back that the harness plugs into. If you had to reuse it, it might have gone bad if it is not charging a known good battery. A normal alternator puts out somewhere around 13.4 volts if I remember correctly.
