- Jul 21, 2021
- Santa Cruz, CA
- 2.3 (4 Cylinder)
Thanks Luke. I think (hope) I've narrowed this down to fueling. Just writing an update while I work through it so I don't forget what happened.
I decided today to follow one of the more obvious symptoms: that the fuel pump isn't priming while this no-start condition is happening. I used a logic probe on pin 22 of the ECU, which grounds the fuel pump relay to energize it while priming or running. It was working correctly. I've never used this tool before, really makes it clear what the ECU is doing.
Next I checked for 12V at the output (terminal 87) of the fuel pump relay during the period it should be priming (but isn't). That is also working correctly. So I'm thinking the problem happens between the fuel pump relay and the fuel pump (including the pump itself).
