Hand Crank Window Problem
Am in the middle of doing the same on my driver side and was wondering how many rivets are holding the regulator on.
if its a manual regulator then theres just 4 rivets ,but if electric theres 1 more holding the motor to the door.
thanks for the offer 94...but i will probably procrastinate until the regulator fails completely :black_eye:
to bad you guys aren't closer (or me closer to you) I can do one of those regulators in about 20 mins. I do quite a few of them at work on our big trucks.
...take an airhammer with a pointed bit, and feather the trigger to punch the center pin through.
An AIR HAMMER? Please do not use an air hammer. You will more than likely shatter the glass on the first hit.
Just take a sharp drill bit on a semi slow speed and drill right thru the rivets. If your not getting anywhere drill a bit faster untill the bit starts cutting good. Nice and easy and you won't have to buy a new door glass. Door glass is way more expensive than taking your time and being safe.
Mine is doing the same damn thing now, i refuse to pay any money for a skipping window, i'll go the junkyard before i go to a stealership.
