- Mar 16, 2024
- Olympia, WA
- 4.0 V6
- Automatic
- Tire Size
- 33’
Hello all! Hopefully someone here can help steer me in the right direction with this problem.
I have a '94 Mazda B3000 2WD and for a while now, it has been making a slight grinding noise at very low speeds that has gotten worse over time and is now quite noticeable. It doesn't occur while tracking straight at all, but if I am accelerating from a stop or at low speeds (No more than 10mph), it will start vibrating and shaking the pickup and almost feeling like it is binding. If I am making the same low speed turns and coasting, it will make a groaning noise that speeds up or slows down depending on how fast I am going. Sometimes, if I am accelerating too fast from a stop, it will feel like it slips and I lose all power until I release the gas pedal and press it again. I was originally chasing this as a Transmission problem, but I took my truck to work and put it up on a lift and the rear axle shafts felt like they had a lot of slop in them. I did my differential fluid about 3 weeks ago and the fluid didn't look the best, but there was also no metal in the fluid. Put new fluid in with friction additive and the problem seems to be getting worse since then. This morning it started sounding like it was making a howling noise at 60mph on the freeway.
If anyone else has had an issue with this, I'd love some input. I know the Torque Converters in these to be a common point of failure which is why I was originally chasing this as a transmission issue, but with the way the axles felt super loose (sitting on the ground, If I kick the tire it even sounds like things are loose and hitting against each other) and the howling on the freeway this morning, I am stumped. Any help is greatly appreciated before I bite the bullet and take it to the Ford dealer.
